#31 | |||
T1 TE50 P01
![]() Join Date: Dec 2004
#32 | ||
Yeah i figured, thanks for the advice and info!
There definitely coming soon, and ive found a diff out of an xr8, but i dont know whether to put the 3.45 in or wait and put 3.73 gears in, 3.45 goes well in mums xr8 but mine having that extra 150kg over hers i think i might need to go 3.73 to get the same feel. What are your thoughts on gears?
Current Car: 2002 AUII LTD 408ci Windsor, T6 S488, TH400, 2 Piece Shaft, Helicial LSD 3.23 IRS Daily: 1998 Mitsubishi Super VR-4 Legnum Last edited by mcfly94; 12-12-2014 at 12:18 PM. |
#33 | |||
Q - CAR
Anyways - alls good and I'm signing off this post now as Dave seems to have things covered ![]()
AU FORD STROKER 347 Windsor Stroked; (10:2.1) / TFS 190 heads / TFS R Series 90 manifold / Accufab 85mm Race TB / 90mm Lightening MAF / K&N 90mm pod CAI / FTI custom cam (230-236 @ 50) / Bosch 36lb inject / MSD coil + leads / ASR 8lt sump / Mcleod RST Twin Plate Clutch / Pacemakers PH4006 + 3" single exhaust / BA Premium brake pac / Pedders Xtreme coil over shocks / 30mm Whiteline sway / 3.45 LSD / Custom FG bonnet / Ghia interior upgrade / Enkie Rims - staggered / Quarter Horse tuned. |
#34 | |||
T1 TE50 P01
I've got 3.91s in my T1 with the T5 manual and it sits at around 2600rpm at 100km/h. I would say of the mods I've done so far it was definitely the one which made the biggest improvement. Fuel economy hasn't suffered at all, if anything it improved. |
#35 | ||
Peter Car
I'll back that up, my economy has improved too, although most of my driving is around town where its most beneficial. Although with a BTR it sits on 2250 rpm at 100 kph, not as high as your's Bottledup.
#36 | ||
Q - CAR
Whats a BTR ??
#37 | ||
T1 TE50 P01
#38 | ||
Q - CAR
OK - called on my trusty friend Google.
BTR - 4 speed Auto transmission ..lol HAHAHA - thanks Dave ... we posted at the same time ![]() |
#39 | ||
Q - CAR
Just on the topic of diff gear swap ... When you say your going to swap over the gears in an xr8 diff ... Which I am assuming is the 3:45 ratio to 3:91 ratio ... What does that actually entail regarding parts to swap and estimated cost of labour ??
For when I enquired into it I was quoted around $1600.
#40 | ||
I can get labour done for around $500 and gears for around the same
#41 | ||
Are you on 3.91 too?
#42 | ||
Sick Puppy
3.9s were the best thing I ever did to my 5.0 T5 AU ute.
Improved fuel economy and just made it so much nicer to drive. Might even do it to the missus 5.0 AU3 Ghia one day. |
#43 | ||||
Peter Car
#44 | ||
Q - CAR
My guy was saying .. If you replace the gears you need to replace something else ?? Can't remember ... Plus he wanted to use gears purchased through Herrod ... Plus his labour charge ... Hence the $1600 price tag. He did say he would install ebay gears but would not warranty work (
#45 | ||
Peter Car
Diff bearings probably. Mine were replaced at the same time the gears were fitted.
#46 | ||
[EBGLT]
Hey guys,
Great read in here I got a lot of info. Im in the middle of doing some mild mods to my 302 aswell I have a list of the parts I have so far. Trickflow Manifold Pacemaker PH4000 YT 2028 Roller Rockers Crane 444225 Cam 24lb Injectors GT40p Heads AU xr8 motor Series 1 Just a bit unsure on what sort of valve springs I should be looking for.
[EBGLT] Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/ |
#47 | |||
Q - CAR
Send a pm to bottledup ... His a genius with the ford building specs
#48 | ||
[EBGLT]
Yeah I have just waiting for him to get back to me.
#49 | ||
Q - CAR
Simplest way is to go on Fordstroker website and look at their beehive Pac springs ... That's what I brought. And you will also need new lifters and Fordstroker seeks the good gear at affordable prices. ... And yes pushrods
![]() More so ... Just email fordstrokers owner " Jim Woods" and he will take care of you
